I've got a brand spankin' new TKO for my '68 and I need to load 3 qts of
GM Synchromesh into it. Up until now I've been assuming I just needed to
remove the upper square-headed drain plug, run some tubing in, and dump
the stuff in. But now that it's come time to do it, I want to be sure that's correct.
Is it? Or is there some other way I'm supposed to do this. I got NO documentation
when I bought this thing, and the shop I bought it from is closed for the weekend.
Help!
1966 'A' code GT fastback. Ivy Green Metallic. 327ci. Not terribly stock anymore.
That would be the method of choice.
Discussion Starter · #4 ·
I guess I stopped because from under the car, it just didn't look like 3 qts of
anything would fit in the space below that fill plug. I have visions of pricey
Synchromesh running all over my floor. I guess I'm just being anal - is that bad? :)
Hey, at $8 a qt its ok! That stuff ain't cheap, let alone the fact you have to tread upon a GM dealership to get it... Guess there was one downside to getting a Tremec /forums/images/icons/smile.gif
