1 - 2 of 2 Posts
I have spent the last month trying to install a tremec in my 73 mustang. I finished yesterday started up my engine, put it in gear and sat there. ::
Well I suspected that I had managed to damage the clutch during my install so I fought off the urge to just let someone else do it like my roommate said in his famous "Do It Right The First Time" speech, and I got under my car and pulled the tremec. I discovered that my suspicions were correct. I had totally destroyed the clutch disc. The gear in the disk was shattered. Why did it shatter you may ask. Well its simple I did something stupid. Well a few stupid things.
By the way is it possible to get your girlfriend into working on cars?
Anyway First I lost the instructions that came with the clutch then I assured myself I had gotten all the right parts without double-checking.
The gear in the clutch disk was crushed by the input shaft in the tranny because it was for a different tremec transmission and has like a 26 tooth gear. The Tremec 3550 has 10, Amazing!!
Well I got the new clutch in and the tranny went right in with only a little cussing. Now I just have to hope I survive until tomorrow so I can finish the job.
I was supposed to go out to dinner with my girlfriend tonight not work on my car again. Opps.
I'm amazed that you were able to get the input shaft through the old disk. It is a major pain when your laying under a car trying to get the trans to slide in... I'm sure the new one will work. Are you useing a cable or Z bar setup for clutch actuation?
1 - 2 of 2 Posts
