1 - 20 of 34 Posts
66 coupe. 302. I’m hearing a high pitched whine from my engine compartment. If the normal engine sound is a baritone, this pitch would be on the scale of an alto.
Details.
It occurs when I first start the car and the choke is engaged so the car is at higher RPMs. Then it goes away and it typically occurs when I accelerate aggressively. I can be cruising at 60 mph at 1500 RPMs then downshift to 3rd(AOD) and the whine shows up. Normal driving I usually don’t hear it.
I hear it from the passenger side of the car when I‘m driving. The sound increases at the same rate as the engine RPMs.
I took it to my mechanic who does all my work and actually installed the engine 1.5 years ago. He just blew it off saying it might be a fan belt. I’m not sure he is correct.
Any thoughts?
Thank you
Allen
I have a serpentine belt that has been tightened with being able to push it down 3/4 inch between the alternator and the AC compressor (the longest section of belt). Should it be tightened more?
Allen
Air whistle in the pcv or a vacuum hose loose?
How can I attach a video so you can hear the whine?
Checked the engine. Hose to PCV valve was loose. Vacuum hose connection on car was loose. Tightened both. Adjusted serpentine belt to 1/2” of displacement. We will see how it sounds tomorrow.
Allen
Discussion Starter #10
Still whines today. I’ll take it to another mechanic. Any references for a mechanic in the Seattle area? I live in Woodinville so would like one within a reasonable distance.
Allen
1967 Mustang Convertible
Have you pulled the belt off and just spin each accessory pulley? Sometime you can hear a bad bearing going out on the alternator, water pump, etc?
Discussion Starter #13
How about Bel Kirk Mustang
I’ve had mixed results with them. It’s been a few years since I’ve used them. The mechanics are new. Have you used them recently?
Discussion Starter #14
I haven’t done that. It’s raining right now so a good time to work in the garage. I’ll try that.
Thank you
Never have used them. i do my own work at home. If you ever need body work or paint let me know. My wife does restoration work.
Discussion Starter #16
So I removed the serpentine belt and spun the water pump, AC compressor and alternator. Compressor, alternator were quiet, The water pump had a friction sound with spinning in. Kinda of like a door with hinges that need lubrication. Culprit? I’m assuming it should spin quietly as the others.
If I need to replace the water pump, is a high flow pump better than standard?
Thank you
64 1/2 D Code Coupe,
Thank you
I don't know how a high flow water pump would cool any better. The coolant that just passed through a hot engine needs time to cool off in the radiator before going back into the engine.
Discussion Starter #19
Does my description of the friction noise heard with rotation of the water pump indicate that likely it is at fault?
Allen
Allen
Try Bel-Red mustang, I take my car to Blood Enterprise, but they're located in Auburn where I live.
Another place you could try is Mainly Muscle Cars. They will be able to at least provide you a name/business to contact. And lastly, just do a search for classic mustang repair in Google. We have a lot in our areas.
Good luck👍😎
1 - 20 of 34 Posts
