My 65 Fastback A Code project is coming along nicely. Over the summer, the 289 was transformed into a 347, and I’m researching what motor mounts should use. I’ve read everything I can find about the different motor mounts used from 65-67, and I’m also aware of the TCP and Ron Morris mounts.
Initially, I was thinking about using the TCP mounts, but I’m concerned about vibration. A couple guys have mentioned hitting a harmonic between 2000-2500, which is right where I’ll be running at highway speeds, since I’ll have a 4R70W & 3.55s behind it. So, that got me wondering if it would be worth spending $400 on the original 65 HiPo mounts. They have the strength needed for my 347, will obviously work with my HiPo exhaust manifolds, and hopefully will provide better vibration isolation that the various aftermarket options.
Thoughts?
Thoughts?
