Is it possible to get too much fuel to the secondaries of my carb? My motor is being overwhelmed under hard acceleration, causing the car to hesitate. I am finding black smoke in the back of the carb. I checked the float level and it seems to be adjusted properly, just below the sight plug.
You may want to look at holley's downloadable carb calibration list and reset your holley to factory specs....and start over with tuning.
http://www.holley.com/HiOctn/ProdLine/CarbList.pdf
right click on this link and save it to your pc....good resource for calibration ideas!!
you'll need the adobe acrobat reader to read it
As a baseline, have someone observe the tailpipe emissions while you attempt to duplicate the condition. Note any unusual emissions.
Then, disconnect the vacuum pod accuator rod from the throttle shaft and re-try. I would recommend securing the shaft to remain closed for safety...it shouldn't roll over but, on a big engine, you never know.
Instinct is accelerator pump circuit... secondary possibility is G-induced lean-out from fuel level in secondaries uncovering jets. Especially problematical in applications like my race car which have fairly high G loads upon initial acceleration.
Lastly, due to same condition, primary metering can change due to fuel level interfering with vent flow...
Get back to us with some more observations...
