Morning experts, cold again in TX. I have a 289 k-code, Edelbrock intake, Holley 600, headers and MSD ignition. What size Jets are you guys running?
The ones that provide the proper main circuit air/fuel ratio for the engine configuration. The answers could vary across the board depending on the intake, carburetor, headers, camshaft, timing curves, fuel formulation, air bleed size, booster type, etc.Morning experts, cold again in TX. I have a 289 k-code, Edelbrock intake, Holley 600, headers and MSD ignition. What size Jets are you guys running?
So could "plug reading" and/or a wide-band AFR gauge....I would have to say,
A Dyno could be your friend!![]()
Start with whatever jets are stock in your carburetor model.Morning experts, cold again in TX. I have a 289 k-code, Edelbrock intake, Holley 600, headers and MSD ignition. What size Jets are you guys running?
I think most 1850's were 65's in the primary side...... haven't looked one up in awhile.Start with whatever jets are stock in your carburetor model.
At least for sea level that's a very good starting point. Usually it's everything else but the jets that needs to be tuned for the application. Like the idle feed restrictors. Which are fixed.....Start with whatever jets are stock in your carburetor model.
…and there’s a way around that 😉Like the idle feed restrictors. Which are fixed....
...with a drill bit.At least for sea level that's a very good starting point. Usually it's everything else but the jets that needs to be tuned for the application. Like the idle feed restrictors. Which are fixed.....
https://www.summitracing.com/parts/qft-7-7-10qft or there's always solder.....Hard to drill them smaller though 😉
(and yes, there are ways around that too)
Spot on.I think most 1850's were 65's in the primary side...... haven't looked one up in awhile.
