1 - 2 of 2 Posts
I have a Holley 700 double pumper that has 4 corner idle circuits and dual front and rear power valves.
Once you've determined the correct size primary power valve should you use the same size in the secondaries??
Thanks in advance ::
I would for simplicity's sake....
But my most accurate answer would be depends on if the linkage is 1:1 (primaries and secondaries open at the same time and rate), or if the linkage is progressive (primaries first a little bit).
1 - 2 of 2 Posts
