1 - 2 of 2 Posts
On a 69 -70 mustang that uses the 2 rear of carb studs bracket to hold the linkage mount for the throttle is hitting the large rear Holley vacuum port that exits the rear base of the carb. Any ideas ? Is there a different bracket? Do you remove the port?(this can be done) because there is another port directly below it in the 1" spacer? Anyone deal with this clearance issue?
I had the same issue. The factory bracket won't work with the Holley, you'll either have to hack up the factory bracket, or buy an aftermarket one. I ended up buying the Holley bracket for mine. If you have an automatic, make sure to buy the Holley kickdown lever adapter kit, they don't include it.
1 - 2 of 2 Posts
