1 - 11 of 11 Posts
I had my 69 coupe hood and deck lid chemically stripped. The stripping process removed the adhesive between the inner frames and the skins . What can I replace this with?
Thanks TOD ::
Use 3M seam sealer. It comes in a caulk tube from Virginia Classic Mustang.
Bunker Hill? I thought that was in Boston.....
This may be bush league, but I'd try Liquid Nails. That stuff is incredible ! Plus it's made to be an adhesive, and will dry hard and paintable. Dickson
I hate to dredge up such an old thread, but I am facing the exact same issue with my 67. While cleaning the paint off the underside, a wad of adhesive/sealer separated from both surfaces and came out. Any new or improved products/procedures in the last 16 years?
Any auto body paint supply store can sell you a two part epoxy that is made specifically to adhere skins to frames. It is used in modern day accident work. I used it on my hood skin with no problems.
Lord fusor makes all kinds of epoxies, sealants and adhesive for automotive applications.
Reactions: Wiseguy59
The material between the panels is not intended as an adhesive, it's used to prevent them from vibrating or "oil canning". A tube of paintable seam sealer will do the trick.
Reactions: awhtx
Thanks guys. The oil canning and vibration are my main concern, as I noticed a very slight deflection in the skin when pushing in that area. I will probably give the seam sealer a shot.
Make sure what ever you choose has minimal shrinkage. You'll have low spots on your hood skin if it shrinks too much.
Reactions: Caper50
1 - 11 of 11 Posts
