I have tossed 2 new hood lip mouldings and rejected at least 5 more. The one I am using right now is resaonably straight but has some kind of regularly spaced nicks from the stamping or rolling process. The real problem I'm finding is that all I have looked at....even some alleged NOS pieces...have the center peak of the bend OFF CENTER. The peak is off to the right of center approx. 1/4 to 3/8" on all of them.
I'm using the slot for the center screw as a reference point. My original piece (a little too peppered to re-use) seems to peak right at the center. Is this actually how they have always been made? What are the rest of you doing for a correctly centered piece???
Not sure about your year, but on my '68 I bit the bullet and found NOS. I did the same as you, fit one and it was off center and misaligned. The two ends were visibly different curvatures with one sticking up 1/4" above the hood. Took it back to the shop, checked every one they had (about 20) all mismanufactured.
Their attitude.... "oh well, close enough... sure you don't want one?" Not. :p
Ya know what? My original is good enough to restore. The pecks are so small I'm sure they can be worked out and thoe whole thing polished and coated. It's a much better material than the new ones and the peak is so close to center I'm not going to waste time on anything else.
You have to center them, no big deal, just work it around so the holes line up. Never had a repro or NOS that I couldn't make fit.
