If you are burning up horn contacts then you have much bigger issues with traffic where you are causing you to use your horn that much. Course I used mine a bunch today to and from the swapmeet as I always get stuck behind the cars going 45mph on a two lane road that is 70mph and virtually no passing zones.
The preferred method of wiring is to run positive to the horn button. Ford had a habit of liking to have every wire in the car hot and then using a switched ground. This is bad for diagnosis and oh if a wire shorts your horn blows constantly or your dome lights are on all the time. You always minimize the amount of wire in a car that is hot.
Those connectors that you have pictured are standard bulky molex connectors. They get the job done but are ugly and clunky. I have never seen or heard of that plunger being replaced in any GM or Chrysler vehicle (chrysler used the columns in allot of their vehicles) Also that one looks like the regular cheapie aftermarket part and the aftermarket stuff now is garbage. The aftermarket turn signal switches are also garbage now too.
