I have been working to find out why my horns do not work when you use the horn ring. Here's what I found out so far: the horns toot when connected directly to 12 volts and the two 'buttons' on the steering column(after wheel was removed) have power when I jump them.
What do I look for now?
Do you mean the plate that is on the 'bottom' of the steering wheel? That is on there. How do I check for a distorted wheel? By the way it is cracked.
Thanks for the prompt responses.
