Hello all,
My name is Jake, this is my first post here! I am looking for advice and recommendations. My issue is as follows: while driving my 1965 Mustang the other day, the center horn cap on what appears to be a ~10-15 y/o Grant steering wheel popped off and the horn was stuck in an on position. I pulled over and put the cap back on, horn stopped blaring, but now sparks are appearing when pressed.
At home, I took the cap back off, removed the negative contact and electrical taped it and put the cap back on. Now it’s not sparking but then again no more horn. My go-to thought is to just get a new steering wheel as my turn signal doesn’t reset automatically either and I know there are contacts behind that can be fixed in the process of getting a new steering wheel.
That being said, I have 2 questions: 1. Is there a way to fix the issues mentioned above without getting a new steering wheel, and 2. If purchasing a new wheel, what should I get? I see a lot of negative reviews on the Grant, but there is also a Scott Drake in CJ that gets poor reviews saying horn doesn’t work with the kit. So really looking for recommendations on that front.
Thank you!
Thank you!
