I was wondering if anyone could give a horsepower estimate for my current setup.
I built the engine a few years ago to run at the track, but you know how plans somtimes go. Engine has maybe 100 miles or so on it.
An 1/4 mile ET estimate would be cool also.
Ford Muscle webzine looks like they built a similar engine, but I'm not sure how their numbers would compare to mine.
400 horse 302
Heres my setup:
Block:
289 bored .030
stock bottom end all rebuilt and balanced
ARP rod bolts
TRW forged dome pistons
11:1 compression
Heads and Valvetrain:
World Products (Dart II) 351 Windsor Sr. (early castings with the odd “what were they thinking” plug locations)
Manley 2.02 intake 1.60 exhaust valves (5 angle valve job)
Screw-in studs, guide plates, hardened push rods
Harland Sharp roller rockers
Heads milled (along with the block decked) to give a 60cc chamber
Machined for Fel-Pro loc-wire gaskets
Crane solid lift cam: 284/294 (238/248 @ .050) 533/555 lift RPM range 3000-6500 (valve float 6800)
120lbs. Springs
cam set at 106.75 (.032 ahead)
Hamburger timing chain
High volume oil pump, deep pan
Induction:
Holley 700 DP (4 corner idle circuits, milled choke tower)
Edelbrock Performer RPM
Exhaust:
Hooker competition headers
Full 2 ½ DynaMax with H-pipe
Ignition:
MSD distributor, coil, and 6AL ignition box w/ rev limiter
Clutch and Transmission:
Hayes steel flywheel
Centerforce clutch
Lakewood blow-proof bellhousing
Stock 4-speed top loader
Hurst shifter
Rear:
9”, 31 spline axles, traction lock, 4.57 gears
Suspension:
KYB shocks
Sub-frame connectors
Thanks in advance
400 horse 302
Heres my setup:
Block:
289 bored .030
ARP rod bolts
11:1 compression
120lbs. Springs
Induction:
Exhaust:
Ignition:
Centerforce clutch
Hurst shifter
Rear:
Suspension:
KYB shocks
Thanks in advance
