1 - 10 of 10 Posts
just wondering how much a 65 289 v8 makes?
just got the heads rebuilt and about to put all new exhaust in, so just kind of wondering what ballpark im in horsepower wise, thanks.
Well a brand new factory fresh 289 2v was rated at 200, the 4v rated at 225. So, if you want to use these numbers as a reference, it will give you some idea. Understand that the way HP numbers are measured have changed over the years.
I read years ago that figured with modern calculations, a 2bbl was good for about 130HP, the four barrel version maybe twenty more.
The "factory" ratings were with no accessories or exhaust system attached. Probably 125 at the rear wheels.
(actually Slim Jr now)
If you compare the 71 302 2V to the 72 302 2V the 71 was rated 210 hp while the 72 was rated 140 hp. Main difference is 71 was engine crankshaft with no accesories or exhaust system. 72 was SAE net at transmission output with exhaust and accesories.
There was a slight change in 72 lowering the compression from 9.0:1 to 8.5:1. This would account for 5-10 hp.
They would be ~140hp at the flywheel and closer to ~110hp at the wheels.
Discussion Starter #9
well thanks for the answers everyone! i was hoping for more =/ but now im thinking of going and getting a 302 or 351 and build it up and then swap, but that will be a big side project haha.
These cars were quite slow stock and new. A 289-2V did the quarter mile in about 17.5 seconds. A Fiesta is faster!
1 - 10 of 10 Posts
