1 - 9 of 9 Posts
The hose from the thermostat housing to the water pump. I can't keep it from kinking. any suggestions?
Get a hose that's different/new/equipped with an internal spring.
Trim the hose to the proper length and it will not kink .
most of our old cars have CUT TO FIT parts cause they work for many other newer ones. ::
Yeah, I got 5/8" hose, and cut it to fit. No matter how short I snip it, it still kinks. I give up. I tightened clamps around both ends, it should be ok right?
Just some guy
This an application specific hose. You can't use regular old heater hose or it will indeed kink everytime. You need to by a "small block Ford bypass hose". It's not very big and pretty cheap. It has the 90 degree angle you need formed into it. There is no good substitute that I know of. And I've tried. I know keep a spare in the garage since we have more than one smallblock vehicle.
not true. You could leave it 5" too long, and make a loop to keep it from kinking. ::
1 - 9 of 9 Posts
