·I have a '69 428 Q-Code with C6. When cold it starts no problem but when hot, the starter does not crank at all. It might crank it over about 10 degrees if that. Eventually a 10 degree crank will get a start, so the actual engine is very easy to start but the starter motor will not crank. I have replaced the starter motor with a new unit and checked the leads to no avail. I have also put insulation around the starter motor to protect it from the heat. Anyone from the hotter states have any ideas? I am from Australia so it can be hot here in the summer, over 100F, but the problem even happens at 85F
