Like everything else I assume you need to maintain a convertible top mechanism, do you have to grease off certain places to make it last longer and operate easier etc...
WD-40? Lithium grease? Bearing grease?
what do i need to use and were do i grease
btw I mean the the convertible top, not the underside of the car
If you're looking for zerks, you won't find them. Just use common sense, any where there is a pivot point or sliding joint.
Do not use WD40...it's not a lubricant. Most any lubricant would work. Lithium grease works.
Dave
(actually Slim Jr now)
+ lithium. Pivots, pins, sliding rubbing surfaces.
