1 - 12 of 12 Posts
going to look at a 65 fastback in a few hours and the owner states the car is a real GT but does not have original engine. when looking at the car, how can i tell if it truly is a real GT?
I just did the same thing,only a coupe,it has to be a A or K code,under the rear seat where the dual exhaust brakets are theat area has extra supports,large masterc ccylinder/proportioning valve/4 piston disc brakes,larger front sway bar ,punch outs in the radiator support for the fog lights-not drilled, special code on the steering box for quick steering,rear valance cut outs,good luck
It will need to be either A code or K code. Not produced untill Feb of 65. Look for the steering box tag HCC-AX or HCC-AW, Sway bar is 13/16", 4 piston disc brakes on the front.Reinforced exhaust hangers behind the rear seats. no quarter panal trim on the scoop. It will have a five dial cluster. Hope that helps. The only real way is with the original paper work when bought new. I got lucky when I bought mine It had all the documentation from the day it was ordered.
If the car has the buck tag under the hood it should have PI or PIO on it for Performance Image Option.
only the 65-66 K got the 9" and that was part of the hipo package not the GT package.
Yep.
Only one year was this different. The 68 J code GT got a 9", while non-GT J codes did not.
Here's a good look at the rear seat reinforcing plates. The paint has been removed from them during rust repair:
The one sure indicator I did not see mentioned in the sites of the previous post is this: the factory GT used the same rear end as the K Code and the snubber plate above the differential has square corners.
No. Only the K code had the 9". The pinion snubber was bolted to the floor on 8" cars, and hits a lip on the pinion housing. On the 9" cars, there was a larger plate welded to the floor, and the snubber was bolted to a large bracket on the pinion housing. The 9" floor plate is available new.
.... the snubber plate above the differential has square corners.
Here's photo of an "A" code GT's snubber plate which my factory GT has. My 6 cylinder Sprint 200 & "C" code FB both have the round corner plate. Dean
1 - 12 of 12 Posts
