how can i tell if my 67 was made before or after feb 1st
thanks
One of the simplest I know is to look at the brake lines on the firewall by the steering column. Before FEB 67 lines pass UNDER steering column and after they pass above...If you have time, you can call FORD customer service and they will send you a full report on your car...I don't have the number handy but if you do a search on this site, you should come up with it.. Don't know how it compares to a Marti report because I don't have one of THOSE but the information I got from Ford was exactly what I was looking for including build date, tires, options inside and out (i.e. G.T.) original color, engine, transmission, rear end...Took about two and a half weeks(although they said it would take up to six). Good luck and hope this helps...
