1 - 13 of 13 Posts
Noticed my driver's side door on my 1965 Ford Mustang Convertible "drops" a little when opening. How do I correctly realign the door so its opens and closes correctly? What parts do I need and steps to correct this? I keep reading posts about hinges vs repairs kits. Below what I need?
Door Hinge Repair Kit 1965-1967 Thank you! MD
748192
If the drop is caused by looseness in the hinge, that's a good idea. Of course, it may just need adjusting.
1967 Mustang Convertible
Open the door and lift up on the bottom back corner and if there is movement then its the hinges. I had to rebuild mine which I did before painting the car. Once that was done there was no more slop/wiggle when doing the same test.
Adjusting is easy. If the front door gap is larger, loosen the upper hinge (while supporting the door with a padded jack) and raise the door slightly, to match the quarter panel. If the rear gap is larger, adjust the lower hinge.
Make sure the metal holes are NOT wore out, if so the kit will do you no good.
Thank you I found some videos of what to look for. Next step is to test on the mustang to see what looks to be worn out. Local bodyshop quoted 300 a door so I think I can accomplish this on my own.
Thank you I found some videos of what to look for. Next step is to test on the mustang to see what looks to be worn out. Local bodyshop quoted $300 a door so I think I can accomplish this on my own (hopefully)
Much easier with fender off.
Even easier than fender removal if you just get a hinge wrench. Adjusting the door takes under an hour with one of these. Support the door with a padded jack to keep it from dropping.
Reactions: Cobra6
Very cool wrench. Even with the right equipment I fear I would still be a hack...
Not sure why these old posts are popping up, but - this iis the tool for the job. It was made by Snap-on for Ford, but it was discontinued several years ago. You might run across one on eBay or a garage sale if you are lucky.
The first time I used mine I couldn't believe what a difference ot made. It has the head angled at 38 degrees and fits over the door hinges perfectly.
1 - 13 of 13 Posts
