I have gotten my 65 to the place that I hooked up the battery and she turned over after that Long sleep?
The ignition switch seems to be a bit ruff, and the switches slide badly. After I turned her on the dash lights stayed on
after the switch was off. What should I use to clean and lube ignition switch?
I have WD-40 will it work. Oh what's a good way to hold the battery down in my 65?
Next task install new hard line to tank and new tank install.....
739076
739077
The ignition switch is pretty cheap to replace but the contacts would clean up well with a small wire brush or a brown scotch brite pad and maybe a little spray of electrical contact cleaner or perhaps a sprinkle of baking soda and a couple drops of vinegar. Dry well. A couple drops of 3 n 1 oil on the key will be good for the lock cylinder.
Reactions: kenash
all the ábove except I would use powered graphite on the key for the ignition cylinder. Any liquid oil will attract dust and grit, things seldom desired
Z
I used Deoxit 5F on my crunchy light switch that had been sitting 33 years, it now operates smoothly.
The F is for electric faders and provides a little lubrication to contacts the slide. So far very happy.
Gregg
View attachment 739076 View attachment 739077
1. In a clean 16oz container, mix 12oz Diet Pepsi with 2oz Captain Morgan's Spiced Rum. Set aside.
2. Order Standard Motor Products ignition switch, part no. US-74 from rockauto.com (see attached).
3. Consume your alcoholic beverage and relax.
4. When part arrives, toss old one and install new one.
NOTE: Places like O'Reilly's may have or be able to get same switch for equal or less cost than rockauto.com plus shipping....
739149
