easiest way I can tell..without expensive equipment..disconnect the coil wire from the Dist. hold it against the block..and crank the engine..you should get a nice clean blue spark about half an inch long..if it has any red or yellow color..the coil is usually bad or on it's way out
even easier is if you have a old spark plug gap it to .5 and put it on the wire to the dizzy cap and check the spark
Oh man....lol...
I was gonna recommend you pull the coil wire and hold it while cranking the engine.....
If your hair stands up on end, it works.....if nothing happens order a new one.
