First open the trunk. Then to remove the lock cylinder from the sleeve assembly, turn the key in the lock 1/8 turn clockwise, depress the cylinder retaining pin (the little ball in the little hole) with something pointed and the lock will turn and pull right out.
Takes a bit to get the feel for it, but once you do you can pop these things in and out in a few seconds.
Good Luck,
