How do you keep the rubber piece in a 69/70 automatic shifter from melting besides unplugging the light? I am talking about the black rubber piece that is split for the shifter handle to slide through.
I've never heard of them melting, are you sure it's the right bulb?
No matter what, a lower wattage bulb = less heat.
Yep, sure it's the bulb. The bulb was burned out, but I had changed the rubber seal. Everything was fine, then I decided to change the bulb. It melted within an hour. Has anyone else had this problem with their 69/70's?
I bought an aftermarket one that melted without any bulb at all. I had redone my bezel to put in my 69 and was in a box in the shop.
Bruce
I had an original one that would stick to the chrome shifter handle and would tear apart from the mounts. I'm currently not even using a seal because of the headaches. A good lube would have prevented my problem. If seemed like a really soft rubber though, so I can see it melting easy.
Well... You do NOT put your NOS replacement in the attic with the rest of your NOS parts during the Texas summers, don't ask! :)
No kidding, You should have seen the old dresser that had 150 pounds of candle wax (abandoned hobby of a female relative)!!
Had a model of a Cobra that sat on a cabinet in the shop for years.
Finally reached up to pull it down and it had just sagged...the tires were flat...and stuck.
Bruce
