its not coming out easily, im afraid ill break it so i thought id ask you guys first
It has a tab with an integral collar that wraps around the speedo "neck"
This collar has to be moved to one side (it should only move one way) and then the cable will slide off.
The first thing to do is to remove the cable from the transmission. Then push it up through the firewall to give you some slack. Then, take out the screws from the cluster and unscrew the cable for the back.
On a 69, squeeze the tab on the white collar and pull out...doesn't screw in.
