·Guest
According to my manual, you use Ford special tool XXXX to adjust these rods. Well, I don't have Ford special tool so I made my own by looking at the picture in the book. I tried using both 16g sheet metal and a block of wood, a 1x4 I think.
All I succeeded in doing was damn near killing myself! I managed to get the rod popped off the bracket both times, and it took me forever to get it back on. I understand how the tool is supposed to work - the notch at the top is where the bar sits in the tool and the hole at the middle slips over the end of the bar - but there's a problem: as you start pulling the bar back, putting more tension on it to get it in the next bracket slot, the bar is flexing, meaning the end of the bar is moving AWAY from the tool. Since there's only a stub of the bar sticking out as it is, it only needs to slip just slightly before it's out of the tool and whips out of the bracket.
Anyone got any ideas? I can successfully get the bar into the first slot in the bracket from when it's disconnected with the tool, but if I put any more tension on it to get to the next bracket slot out it comes. It really sux because my trunk whacks me in the head if I'm on even the slightest incline...
Visit my repair page for Repair info, with pictures! http://home.dencity.com/mustangcub
