If you switched your sys. to Dot 5 brake fluid how well does it perform. Is it as good as Dot 3 when stoping. Did you notice any difference in your pedal. Did you just drain your calipers and wheel cyl. or also flush the sys.
I am thinking of switching only because I have the master cylinder out and like the idea of not having to worry about Dot 3 (paint removal) after I am done with the engine and engine bay repaint and detailing. Thanks for your feed back.
