Just got the new choke tube set from NPD. WTF! This thing has some way wrong angles on it. The bottom of the cold air tube is almost 180 out, and the hot air return is going to need 2 new bends if it is even going to get close to the choke housing. I know a little is to be expected, but man, I would have bought the raw freakin' tubing and bent my own if I knew it was going to be like this. Should I complain or lump it?
They must have sent you the wrong one. Nothing should be that far off. Good Luck.
Mine went in like a charm, once I figured out which pipe went where. No bending at all. The worst was getting the pipeclamp on both pieces without rotating the two pipes around one another. Total job took about 3 minutes....
