1 - 2 of 2 Posts
I'm in the process of finishing my custom fan shroud and I wanted to know how much clearance should I allow between the outer tip of the fan and the inside (I.D.) of the shroud?
FYI - My fan is 16" and my aluminum radiator is 20" wide (not including the radiator tanks on each side).
Thanks in advance!
I don't think there's any "rule of thumb" here but you certainly don't want a huge clearance or the shroud will be ineffective. My guess, and it's pretty much what I have, is about 3/4 inch.
Also, you want the fan itself to be pretty close to the radiator, like within about an inch or so.
1 - 2 of 2 Posts
