1967 Mustang Fastback, deluxe interior. 351c 4v.
HOw much oil do I need for this thing? 1970 351C... I just did an oil change and added 5 quarts to be safe, plus a pint of SeaFoam. Should I adda nother quart or half quart?
I'm curious as to why you added Seafoam to the oil? I have only heard and used it in the gasoline of marine outboard engines to clean carbon deposits.
IF you read the cans, it's for auto or marine, you can add it to the gas tank, carb, or to the oil. This engine has sat for 15 years and I added to all three. Works real well. I also get a special SeaFoam stuff for automatic trannys. Did that too. Most people I know around here hold it in high regards.
Incorporated Sell Out
Why would you want to put 6.5 quarts in a motor that takes 5? Do you have a non-stock oil pan? Did you remember to pour some in the oil filter before screwing it in?
I find that if I pour oil in and then pull the dipstick and look I quite often know how much oil is in the car and/or how much additional needs to be added ;)
Discussion Starter · #5 ·
Hmm, well for starters I didn't put in 6.5 quarts. I put in 5... plus a pint. I wasn't sure how much oil this engine took. So THAT is why I was asking how much to put in. I have never worked with a 351 until yesterday. I'm used to big FE engines. I didn't know if this was a 5 or 6 quart engine. So I did 5 and then asked.
But did you pull the dipstock and check?
The reason is simple, if it hasn't been run in a while, although the car is generally full with 5 quarts, you might end up needing to put another 1/2 quart in. Is the dip stick not functional in the car? If so you need to rectify that sooner than later.
I am not trying to give a hard time.
according to all the literature I have the Cleveland holds 5 quarts..manufacturer suggests 10W40..with the pint of Seafoam you are a little over..I would just drain a bit off..I have never heard of Seafoam on the East Coast..what is it?..just curious
I have the baffled oil pan and run 6 quarts. I have a high volume oil pump, oil scraper/windage tray, and the baffled oil pan.
The boss 351 used 6 quarts with only a recalibrated dipstick and baffled pan.
The baffled pan is the same as any other except for the fore mentioned.
