I have a "clunk" and small lurch when I shift from forward to reverse and have been told it is most likely my universal joints. I crawled underneath today to check them out and grabbed the driveshaft to see if I could move it and detect any movement in the u-joints. I didn't notice any u-joint movement but I did notice that I can rotate the driveshaft about 1/2" or so each way. Is this normal? Are my rear gears worn, loose or otherwise? Any help?
When I can't stand, I must lean...
When I can't see, I must believe....
