1 - 11 of 11 Posts
I've got three power brake pedal supports and I'm only sure of the origins of one. A 73 stang I pulled it from. I've got two others that I was sold being told they were for a 69. Neither fit and I ended up using my original drum brake support and getting it to work just fine. Problem is I have these supports taking up space but don't want to misrepresent them when I sell them. Don't have the ability to take and post pics at the moment so was wondering if anyone knows where reliable pics could be found.
I've got one that matches up to that 69/70. But if I recall the under dash mounting plate wasn't the same. Which is why I went with drilling out the manual support. The other one I have has the same firewall mount but the underdash piece is wider and has two square nuts welded into a cage.
Working on some pics
I notice the seller notes that it's a 4/69-70 piece. Were they different prior to 4/69? My car is a late Nov of 68.
The link above shows a 69 pedal hanger bracket.
eBayers love to list them as 69/70. Caveat Emptor.
Roger that Matt.
'69 Mustang coupe...331, Fox / Explorer EFI, TK3550, MDL, SoT, TCP, Fays2 Watts, 94-04 Cobra discs
me too me too...
roger from me too...
nate :)
Discussion Starter #9
Turns out its a 70 power brake support and a 69 power brake support. Thnx Matt
Also the 69 and 70 power brake pedals are different... ANyone needs help IDing pedals or supports just email me a pic. I deal alot with them so I can easily tell what is what...
Have 69 M1 changing drum to power disc, the pedal I bought a couple of years ago measures correct with the exception of an additional U shaped arm that appears to serve as a pedal stop, it will not allow the pedal to retract far enough connect the booster linkage I have seen both types of pedals shown for 69`s (with stop and without) need some advice I`m running out of hair Rod @ A.A. Engine
Also the 69 and 70 power brake pedals are different... ANyone needs help IDing pedals or supports just email me a pic. I deal alot with them so I can easily tell what is what...[/
1 - 11 of 11 Posts
