How to install Windshield
804 Views 9 Replies 2 Participants Last post by  Guest
Going to attempt to put the windshield back in my ~66 coupe this weekend -any advice appreciated.Also will eventually be installing the rear window.Thanks
1 - 10 of 10 Posts
put the seal around the windshield, then put a string all the way around the outer lip. put it on ur car. from the inside slowly pull the string out and the lip on the seal should slip right over the metal edges, if that makes since.
Corpus Christ TX
first thing, totally clean the windshield opening. get all the old gunk off completely. then, if you have scraped to bare metal anywhere, spray some primer.
next, lay down black strip caulking 2 wide around the whole opening, on a convertible, you dont have to do the top edge
next, put the gasket on the windshield, do not use any silicone or anything to get it to go on, put the gasket on dry.
next, spray the inside edge of the gasket with some silicone so it doesnt stick to the strip caulking.
get some rope, about 1/4" thick and run inside the gasket
place the glass on the car, make sure it is centered and have someone push the glass while you pull out the rope. ALWAYS pull the rope towards the center of the glass and always hold your hand up against the glass while pulling the rope.
Once the glass is in, use 3M Bedding and glazing compound to seal. Cut the tip small first so you can run a bead inbetween the glass and gasket and then once you have that done, but the tip large so you can pump the rest all around inbetween the body and gasket. Make sure you get the sealer good around the clips. Use a paint paddle to push the caulking down into the crevices. I normally use a whole tube of compound on a windshield.
use something like pre-sol to clean up afterwards. the messy part is putting the mouldings back on. best thing to do is mark with tape on the cowl where the clips are located. makes it easier to know where to attach the lower moulding.
Charles Turner
MCA Gold Card Judge(64.5-65, 66)
'65 Fastback
'00 GT Conv, triple black
Check out my 65 [color:blue]fastback!</font color=blue>
See less See more
Once its in mark where the clips go (marking pen) use your Glazing compound to "pack" it in, Install your clips while compound is soft, Run a bead of the compound inside the outer lip of the rubber too.wipe off any excess that squeeses out..... install your chrome....admire your work!
Ken
99 GTP
97 Yukon
68 GT convert
I could never get one not to leak, I went to Safe- lite and had them do it, They have a lifetime warentee against leaks.
John L. Anschutz
Allen, TX
68 Diamond Blue Coupe - 302
68 Acapulco Blue Coupe - I6 - 200
http://www.dallas.net/~jjmsansc/parts/Stangs.jpg
the secret is the strip caulking. also, a Ford gasket is recommended
Charles Turner
'65 Fastback
When you go to do the rear window check out the bottom corners real close, water tends to pool there sometimes and rust will eat holes into the trunk.
FYI - they did a segment on my classic car on how to put a new winshield in - I think their car was a 66 coupe. As I remember, it was a pretty detailed show. These posts look good - you might want to check myclassic car web page and get the video if you are still unsure.
1967 Fastback, 289, C-code, AT, PS,
motorsport intake and valve covers, Edelbrock 4V, cam - otherwise stock
dark moss green, parchment interior,
GT rear valance and tips
I'd never heard of the strip caulk deal.... I worked for a glass shop for 10 years....granted I didn't install.... but I never saw the guy's use it. of course that was in my younger days and those years are a bit of a blurrrrr.....but we won't go there!
Ken
99 GTP
97 Yukon
68 GT Convert
was originally used at the factory, works great
Charles Turner
'65 Fastback
1 - 10 of 10 Posts
