· Registered
I have a replacement door to put on my 70 Coupe. But the door I have has undercoat inside that is cracking and falling out in places. It would seem good to remove the hard/dried out undercoat so moisture can't get in behind the old undercoat. I tried chipping away, of course loose chunks come out, but a lot of it is stubbornly clinging on. How about some of you who have done this - Ideas please.
After getting it out, I was planning to prime, paint and spray on a fresh layer of undercoat.
· Registered
Eastwood makes an undercoat/sound deadener remover. You might try that. Also, I have heard that regular gasoline works for undercoating removal.
65 Mustang Convertible 289 C-code
Ivy Green with Ivy Gold & White Deluxe Interior
http://albums.photopoint.com/j/View?u=1571514&a=11942607&p=42928766.jpg
an older guy i used to help out used a puddy knife that he warmed up with a torch, so he had a hot knife, then sanded the rest off, if i remember right it seamed like it took forever, but then when you're 15 five min. seames like forever.
Hey, you might try the gasoline and hot putty knife and torch together, I am sure something will get removed.
Don't try this please!
1967 S code GT Deluxe Coupe 65B
1966 Convertible 76B 289 4 speed
1964 Fairlane 500 2DR HT-the new project
1986 Jeep Cherokee 4X4 the "beater"
http://albums.photopoint.com/j/View?u=1573428&a=11959254&p=43023698.jpg
· Registered
I just used a product call "Auto Strip" to remove all the undercoating sprayed in the engine compartment by the PO. The company that makes it is "Klean Strip". I purchased it at Walmart. I had read on the forum that it worked real well and once again I got excellent info from the people at VMF.
Mike Boyle
My car is a Winter Blue 1969 convertible with black standard interior. It has an original (untouched) 302 2V C4 with ~53,000 miles on it.
1994 F150 Extended Cab 4x4
2000 Taurus
