1 - 20 of 24 Posts
I am replacing the front end on my '65 - I just drilled the holes for the Arning UCA drop.
The problem is my UCA and spindle are off the car, and I can't knock them apart - can't hold it and get a good lick with a hammer.
The pitman arm puller I have is too large to catch on the spindle to work.
Is there a good tool out there that will help? As soon as I clean up the shock tower, I would like to reassemble everything.
Can you put the spindle in a vise to hold it so that you can get a BFH to it? A few good smacks on the spindle where the ball joint come through should get them separated.
I am going to try that tomorrow - it just looks like it is hard to get a good lick with a BFH -I was using a stonemason/blacksmith hammer (4 lbs or so).
The LCA came off easily while still on the car, then I didn't have anything to hold the UCA once it came off.
They make ball joint separators so the forks have just the right amount of spacing to get around a ball joint. Like 68Efi said, smack the spindle around the ball joint, that seems to help a good bit too. It might be easier if your just temporarily installed the arm back on the car. Good Luck :thumbsup:
Just did this on my '68.
As noted by 68EFIvet put the UCA in a big vise holding and take two hammers and whack the mounting area of the spindle for the pin on each side simultaneously. 3-4 whacks dropped mine right out...
No vise, mount it back on the car. If you can't do that... not sure... :shrug:
65fast said:
They make ball joint separators so the forks have just the right amount of spacing to get around a ball joint.:thumbsup:
They're called "Pickle Forks".
In my area you can get a set with 3 different sizes for $9.99.
They work great and IMO are a good investment.
Good luck... Bruce
Use the 4 pounder as a backing and strike the oposite side hard with a smaller hammer, in theory the shaft should free up. Imagine squeezing the spindle so the tapered shaft comes out.
Discussion Starter · #10 ·
Got it - I will make one of these this afternoon
(Non-Destructive Ball Joint Removal Tool)
After two nights with a 4 lb. hammer, it is time to try something else.
Gone but never forgetten
Just go to your local Autozone and borrow one of the jaw type separators. What they call the tie-rod separators actually fit better than the ball joint separators.
It's the one in the bottom left of this picture (they can be bought for about $10 at harbor freight):
http://www.harborfreight.com/cpi/photos/92800-92899/92882.gif
Should take about 2 minutes and pretty much zero effort to separate them ... right tool for the right job sort of thing.
They make Pitman arm pullers with adjustable arms. One of the best tools I have. Got it for $40 off ebay.
Discussion Starter · #13 ·
Thanks Johnpro -
I guess I am going to HF - I made the Mustang Steve FAQ separator and bent two 1/2" bolts trying to work it. After three nights with a BFH and the other, I have got to move ahead.
I knew this one was going to be tough, when I hit it on the car, the LCA joint came loose because I hit the UCA so hard.
Remember, I have 235 lbs of meat to put into it plus the temper...............
Discussion Starter · #15 ·
I knew better.......
Went to HF and bought a pitman arm puller with adjustable arms - got it set right - thought the thing was breaking loose - but one of the arms on the puller split into two pieces.
I ready to see how much I will have to pay for a new spindle - or take it to a machine shop and get it separated.
If I didn't have to get new wheels and tires, I would go ahead and get new spindles for a disc brake upgrade.
When I used the separator on Mustang Steve's site, I still had to whack the spindle with the big hammer after I put tension on the separator.
If you already tried that, you have one stubborn spindle... :shrug:
Discussion Starter · #18 ·
Yep - tried that...
looks like it was just luck of the draw for me to get the 1 in 1000 that won't come apart.
Discussion Starter · #19 ·
GT_SCODE said:
Get the one John pointed out. Tighten it up squarely, let it sit a few minutes, tighten a little more, don't over tighten, it will just pop.
Found the one Johnpro pointed out - local HF didn't have it, neither did O'Reilly's, Advance, NAPA could get one in a day or two. Believe it or not, Autozone had one in stock for $12.99.
I am shooting some penetrating oil in the joint, putting on the puller, tighten it up, then come back after supper and tighten it up some more.
Wish me luck.
1 - 20 of 24 Posts
