I believe AFR can mill the 165's down to 54cc with a flat cut. Mine were milled so that I could use them as direct replacements for factory heads without losing compression.
I wasn't planning on pistons either, but when I mocked up the heads and clayed up the pistons, the valve were hitting the piston tops. This was with stock 289 c-code pistons that didn't have a valve relief. Your pistons very well may not have any issue with clearance. You need to check it though.thanks! at this point not planning on changing pistons but never know what happens once i get motor opened up lol.
yes bought them already thanks.Do you already have the heads? Trick Flow has heads with 53cc chambers.
Just FYIa. Send the head gaskets back. Pull the head(s), put a straight-edge across the top of a cylinder and use a feeler-gauge to estimate deck clearance. If you can grab a dial indicator with a magnetic base use that instead. Once you've determined your deck clearance, THEN order your head gaskets, shooting for a quench distance of .038-.042" (or as close as you can get).
b. Stock Ford rocker ratio is 1.6:1, not 1.5:1. There's no reason to go with 1.7:1, especially on the intake side... just get a camshaft with more exhaust duration instead. While we're on the subject of camshafts, IMHO the one you selected has too much lift. If I was going to pick a decent "street" cam in a "roller", from Comp, I'd probably choose a 35-351-8... but that's just me. For our 289 build we chose a M-6250-E303 for a bit more bottom end torque and fuel mileage... especially running 3.70's and a 1:1 high gear.
c. Stick with the AFR's... the difference between 53 and 58cc is going to be about .5 in static compression but static compression is only part of the overall picture.
One final, and oft-repeated (by me, anyhow) bit of advice from an "Old Fart" who was, believe it or not, young and inexperienced at one time long, long ago in a galaxy far, far away.....
Websites and catalogs are GREAT! However, they are, for all intents and purposes, advertising for stuff that vendors/manufacturers, etc., want you to BUY. Selecting the right COMBINATION of parts should be the goal, not the ones that, individually, promise to be the next best thing since sliced bread. One of those things that these sellers use is what I call the "Psychology of Horsepower" that goes hand-in-hand with "Bigger is Better" syndrome... So, think about this for a minute or two. Which engine would you want for a "street cruiser", below...
Small block Fords NEVER used a 1.5:1 rocker arm.... unless somebody stole them from a small block CHEVY. No problem with your disagreement.... you're the one who'll have to drive it, not me.Just FYI
My info was not from catalog or web site, I spoke with companies directly.
Yes The motor spec sheet that was given me by Summit racing for the year my motor was built and it says "stamped steel 1.5 ratio on rocker arms for the motor, this changed in the newer year motors to 1.6 ratio.
The cam was recommended by Comp Cams (on phone with their tech) with that lift, and also same cam was recommended by summit racing , and spoke with AFR (on phone with their tech) and they think will be a good fit for what I am doing and will not have any problems with the AFR 165heads and my set up. So respectfully I disagree with you on that.
Thanks for the info.
One thing I learned, the numbers you get are not as important as the way that it drives. If your peak HP is at 7000 RPM, that doesn’t do much for you on the street. The HP and torque curve is generally what you want to look at. It tells you what your car will give you, and where/when it will give it to you.Any guess on what I will be putting down at rwhp with new set up?
I did, in fact, mean piston-to-head, not piston-to-valve clearance. Thanks! =)I'm sure you meant the piston to squish surface clearance (top of the piston to the flat part of the combustion chamber). Piston to valve clearance should be a little larger.
It's common for a car with a broad, flat torque curve and modest peak power to absolutely stomp a high-horsepower 'peaky' car. When you get to power levels that will smoke the tires at any RPM, then traction - not horsepower - becomes the issue, especially when on the street.One thing I learned, the numbers you get are not as important as the way that it drives. If your peak HP is at 7000 RPM, that doesn’t do much for you on the street. The HP and torque curve is generally what you want to look at. It tells you what your car will give you, and where/when it will give it to you.
Here is another thing I learned, most people (and I’m not saying this is you) don’t fully understand HP. Nowadays, HP is more of a marketing ploy that only tells a small part of the story. The Dodge Charger Hellcat is over 700 HP. Big deal. That 700 HP is not what makes it so much fun on the street because you don’t hit that HP until 6100. Who shifts at 6100 driving stop sign to stop sign?
Yes definitely...that's another thing I checked before installing Jeff's very nice AFR 165s. I also checked piston to deck at all 4 corners to look for consistency and if the deck was squared to the crank centerline.a. Send the head gaskets back. Pull the head(s), put a straight-edge across the top of a cylinder and use a feeler-gauge to estimate deck clearance. If you can grab a dial indicator with a magnetic base use that instead. Once you've determined your deck clearance, THEN order your head gaskets, shooting for a quench distance of .038-.042" (or as close as you can get).
Small block Fords NEVER used a 1.5:1 rocker arm.... unless somebody stole them from a small block CHEVY. No problem![]()
AgreeOne thing I learned, the numbers you get are not as important as the way that it drives. If your peak HP is at 7000 RPM, that doesn’t do much for you on the street. The HP and torque curve is generally what you want to look at. It tells you what your car will give you, and where/when it will give it to you.
I don't think he wants to crack open his bottom end. He should be fine as long as he keeps it below 6000I would replace the rod bolts with some ARP bolts.
Unless Summit put non-factory rockers on the engine, the 1.5 is a typo. If they are 1.5 it will reduce the lift and .050 duration of the cam as those are calculated for a Ford based on a 1.6 rocker.
Agreed. I will run my stock bottom end up to 6k and shift. Knock wood, it has never let go.I don't think he wants to crack open his bottom end. He should be fine as long as he keeps it below 6000
