1 - 9 of 9 Posts
we are going to install one of these from 'Modern Driveline'
is there a good source with good pictures on how to do this?
instructions came with the kit
but they are pretty confusing
also tried, in vain, to find a video on u tube
iowa
iowa
A few of questions for you. Why are you converting to a hydraulic clutch release mechanism? Are you going to a T5 or similar or are you staying with a toploader? Is the car currently a manual car?
we are converting to a T5
is there a way to install w/o drilling new holes in FW
or moving the gas line block down 2"?
thanks
iowa
In order for the M/C to be installed you absolutely have to drill a hole in the firewall for it to pass through. I drilled the hole at the same location as the original clutch rod hole (which was a dimple since mine was an automatic). I'm not sure what you mean by the gas line block?
sorry
i meant the brake line block that attachs
to the inner L engine bay area
iowa
I put one in my 67 and used a 68 distribution block and I have a midland brake booster and it fit, but was a very tight fit and I cursed a lot. Its a good system once you get it installed, which can be a bit challenging on a complete car. I installed the m/c with engine out and underdash stripped, but think it would be much harder on a complete car. If have have questions or need pics let me know. It took me a while to figure out how to properly bleed it out.
Discussion Starter #8
could someone post a pic of the slave on the T5 BellH
thanks
iowa
Discussion Starter #9
i think i will set it up both ways while the engine is out
then, if i decide to use the hydraulic setup
it'll be easier to install
iowa
1 - 9 of 9 Posts
