1 - 13 of 13 Posts
It supposedly is a good engine with an aggressive cam. I pulled the intake. It is very clean as are the heads. I dont ever remember seeing a distributor like this though. Has a pro comp2 cap. Maybe an old school mallory? The pump shaft is a 2 piece.
736582
736580
WHEN I HAD A 351W IN MY 66 VERT I USED 289 EXHUAST MANIFOLDS AND THEY WERE ALMOST TOUCHING ON STEERING BOX AND HAD TO CHANGE IT EVERY 2 YEARS. They do make special headers for that application
why are you yelling? lol. anyway, what did you change every two years? the steering box?
Bart is 100% correct, that's a cheap Chinese ready to throw in the trash distributor from ProComp/Speedmaster/brandoftheday. I bought one a while back just to see how bad it was and I was not disappointed.
Reactions: Woodchuck
Banned
I'd avoid the ProComp stuff, especially their aluminum cylinder heads. They're very cheap and they can have quite a lot of issues with them. Spend a bit more money and get something nicer, likely that's made in the USA. In terms of headers, JBA swap headers work great and there are a few others out there as well. The cheaper ones usually don't fit though, especially the long tubes.
View attachment 736596 View attachment 736596 how tight? Jack up engine to reach spark plugs tight?
mines in a 68. spark plugs are no problem. my headers are the jba mid length ones. they say to use a high temp sealant instead of a gasket which i did outside the car. There isn't much room at all and not really sure i would be able to do it without getting that stuff everywhere with the motor in the car.
1 - 13 of 13 Posts
