I D TAG
1124 20
Hi my I D tag on the fender apron says vinyl top 2 question is what color was a 2 code in 1967? John
Opal frost pearl metallic 67 coupe http://www.jps.net/binay/webdocs/febef75b01.JPG
also have a 95 opal frost pearl G/T BOSS edition convertible belongs to swmbo
1 - 20 of 21 Posts
Id tag on the fender?
Do you mean the Vin on the top of rail under the bonnet (hood)?
Where on that # does it say anything about vinyl roofs.?
do you mean the door tag
We talking 67?
I don't understand.!!!!!!
If in doubt give it a clout
If at first you don't succeed , find a bigger hammer
http://albums.photopoint.com/j/view?u=1584152&a=12055089&p=43600042.jpg
It is a 67 coupeand the tag under the hood right next to the hood hinge it is listed vinyl top 2 they only made two tops for this year but I don't know which one it had. John
Oh, THAT number!
What colours were there?
Black and parchment?
Mine had a black roof. (*now p/ment)
I'll check the number and get back to you.
He is talking about the body buck tag that was attached at one of the fender mounting bolts on some Mustangs. According to the Mustang Club of Germany site that has a lot of the codes, there was a Vinyl Top A (black) and a Vinyl Top B (white). I didn't see a 2 listed there.
For those interested in the site it is at http://privat.schlund.de/f/fmcog/to_alt/bbtd.htm
Our Ponies
http://www.ultranet.com/~bpratt/images/Mach1painted.jpg http://www.ultranet.com/~bpratt/images/65vert.jpg
Discussion Starter · #6 ·
My car was originally ivy gold with vinyl top I just wanted to see if it was the same as yours but this top thing has been driving me crazy can't find the codes anywhere. John
OK on the L/H side ,your drivers side (my passenger side)
Right up next to the hinge area on the top running across the rail
I can see 12 D8 , may be more numbers under the guard.
I never knew that number was about that type of stuff.
What else does it tell you?
How many more numbers in that group are hidden under the guard, sorry fender
The numbers are stamped on the rail, not a tag as such.
By" tag" do we mean a metal strip or something bolted on by one of the guard bolts )(fender bolts)
Top 2 is for black vinyl, checked the original buck tag on my 67, it was still sporting what was left of its top when I bought it.Buck tag on my 67 NJ built car was on rear drivers side fender apron, held on by one flat headed screw.
1967 S code GT Deluxe Coupe 65B
1966 Convertible 76B 289 4 speed
1964 Fairlane 500 2DR HT-the new project
1986 Jeep Cherokee 4X4 the "beater"
http://albums.photopoint.com/j/View?u=1573428&a=11959254&p=43023698.jpg
Discussion Starter · #10 ·
Hi, mine is on the inner fender, it is a seperate tag with serrated edges held on by one phillips screw right in the center and has the following information:
617
12 E4 7T01T241450
65A I 2G
VINYL TOP-2
Discussion Starter · #11 ·
Thanks thats the tag. What are all the other numbers for do you know??? John
Nope , that 's gone with all the other stuff the dickhead PO threw away.
BTW that silver car looks sharp!!!!!!!!!
Discussion Starter · #13 ·
Thanks, it started out looking like this with a freshly rebuilt 289 and C4 auto I spent 2 1/2 years on it and $5,000 to get it like it is in the sig.http://a1060.g.akamai.net/f/1060/597/30minutes/www.zing.com/picture/pc7e1de4f0e257d39a85cd6f4db41625c/febec020.jpg Painted it the same color as SWMBOs 95 convertible
Just going from memory here tonight, anyone else please feel free to correct me,the 617 is a rotation number used only by the factory, the 65A is the body style-standard interior bucket seat Mustang coupe, the 2G is the interior, which looks to be standard bucket seats-Ivory Gold in color, I believe the E4 is build date- in this case would be April 4, 1967, and the I is for the original exterior color-Lime Gold.My car is a Feb. 14 built NJ coupe,vin 7T01S200454, looks like it made it off assembly line a couple months ahead or yours by the vin, which is on your plate.
Discussion Starter · #15 ·
Hi, my other one is a little closer to yours it is 7T01C221906 this one came with an "A" title from florence NJ John
Discussion Starter · #16 ·
It has a C30 build date so that only missed you by a short time John
MY number is 7R01C144597. And this means??
Discussion Starter · #18 ·
Hi, is that the warranty number off of the door tag? I can look up the rest of the stuff on that tag but that looks like a warranty number that is used by the dealer the numbers we were posting were serial number of car and the prodution date from the tag under the hood that is gone from your car. Let me have the rest of the numbers off of that tag and I can look them up for you John
Stepped in to the yard to do some gardening.
I'll get the info and post it a bit later on .
Will start a new thread.
This one is getting to far back!!!
I'll put your name on it
The 1965-73 Mustang & Shelby Body Tag Decoding Book ( Revised Edition ) list Vinyl Top-2: Black vinyl roof.
Top-2: Black power top, Glass rear window.
Top-3: White `` ````````` ``` `` `` `` ``````` `````````.
To order this book contact: [email protected]
1 - 20 of 21 Posts
