A while back I was having problems with my car's charging system, dying while driving, every other ignition related symptoms. I finally figured out that it was one of the connections at the voltage regulator that was done very very poorly, so I put a new connector on it the right way and everything is perfect. While searching the forum for answers I saw a couple others had similar problems, so make sure you check out the voltage regulator!
Thanks,
Brett
Thanks,
Brett
