1 - 2 of 2 Posts
Yes for the T5 manual tranny, however you are limited in the way that you configure the setup. You will need to use the adapter plate setup for the early model bellhousing which means that you will have to use the early style linkage (Z bar setup) or engineer a hydraulic or cable setup yourself. I do not think you will be able to use an AOD because I think to use an AOD you must use the late model bellhousing which is 6 bolt.
1 - 2 of 2 Posts
