BURP!!!!! Just kidding, I got my Gas pressure gauge I ordered from JEGS hooked up last night and it's reading at 6 PSI at idle. That seems a little low to me, Or is it just fine. I just have a replacement mechanical pump on there but i do have a Electric pump gathering dust in my garage I could slap on there. It's a generic inline pump that was rated at 9 pounds if i remember right. It says to mount it as close to the tank as possible, could I run a wire to it from the gas sender wire? Or should i run a new circut? Well if 6 pounds is OK I'll just leave it be. I have a 1406 carb if that matters. TIA
AKA "Fastbackpimp"
http://hometown.aol.com//dasbus73/Index.html
[color:blue]VMF Member Since Nov. 99</font color=blue>
http://albums.photopoint.com/j/View?u=1590185&a=12106882&p=43855504.jpg
6 psi is fine....just stick with your mechanical pump for now...
For comparison, try running the engine up to around 5K and check the guage reading......shouldn't be under 4psi
Pat
Discussion Starter · #6 ·
Thanx, I did rev it up and it dropped a little down to 5.5 and a little below 5 if I really got on it. It seems to run fine and I don't race it so I'll leave it alone.......For Now
AKA "Fastbackpimp"
