1 - 10 of 10 Posts
Now that my posi chunk is back from the 4x4 shop, I'd love to put it in the housing under my 70 sportsroof....damned stuck axle shaft!!!!!!!!!!!!!!
I just LOVE to get a hold of a 20 or 25 lb. slide hammer to BEAT THE LIVING TAR out of the rusted in axle bearing....getting pb or wd40 into the area is difficult at best
maybe I should just heat it gently.
GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR!!!!!!!!!!!!!!
I would go with the heat approach. You probably needed to replace the bearing, retainer and seal anyway.
Good luck.
I hate heating them. Bolt a chain to one lug stud, put something heavy in the chain(I've used cinder blocks, crank damper...) & bolt the other end to another stud & get it on!
back in the 1960s, one of the popular ways for us "teens" then was to use a good chain attached to two lugs and a driveshaft running through the chain with a guy on each side. On the count of 3, we would both yank back and the offending axle usually gave way after a couple of trys.....
randy
How did you get the chunk out with an axle still in the housing?
(Inquiring minds want to know...)
Unbolt the axel from the houseing, bolt the tire/rim back on and use it. Just rock it back and forth untill it comes out.
Banned
OR, use the brake drum on backwards. Probably needs to be replaced anyway.
OR, if the chunk is out of the housing (* you never said it came out of THAT housing*) can you beat on the splined end of the shaft? Obviously you wouldn't want to reuse it, but hey...
Must have been funny to watch eh bossman???.....:)
Kinda reminds me of tryin to yank a baby tooth when I was a lad....
ever try aero kroil??? That stuff works sooooo good.....I have always used that and exhaust bolts have never broken (as an example)
a more "updated" millenium version is to attach the chain to the rear bumper of a 10 second drag car. Just simply take the motor to redline and drop it in drive, and I am SURE the axle will come loose.
*G*
randy
1 - 10 of 10 Posts
