After reading several posts on here about lifter failures and wiped cam lobes, I had an idea that I wanted to get opinions on. I have a 351 C 4V, Crower hydraulic lifters and pushrods, stock rocker arms, and a Summit SUM-5201 cam (which is a renamed Elgin E-CL225-P). My engine is completely put together, and I am waiting on the car from the body shop, which should be in a week or two. I placed plenty of assembly lube on the camshaft and lifters, so I know it is well lubricated.
What I was thinking was - to drain the oil currently in it, and put enough of the Lucas Engine Break-in Oil additive to cover the suction on the oil pump, and then pump the additive throughout the system using the distributor drill technique. It comes in 16 oz. bottles, so I figured 3 quarts should cover the pump suction. This way I will know that everything is covered with ZDDP. After that, I plan on draining the ZDDP and put Valvoline VR-1 prior to startup. It would cost me about $100 to do this, but much cheaper than pulling the engine if it failed.
Any comments, concerns? It maybe is just a dumb idea from someone who is nervous about the startup.
