1 - 2 of 2 Posts
i have a 5.0 v8 out of a 89 f150 in my mustang and it has started to slowly increase the idle as time goes on starts out at about 1500 and increases to about 2000 when it warms up shows a code for the idle air control and the throttle pos. sensor but they are both in limits no apparent vac. leaks either should i just start replacing sensors other than this it runs [email protected]
Check for ecessive wear at the throttle bores. Air will get in there and make it like your hitting the gas slightly. If worn, get a new carb and she should idle nicely. If you buy a rebuild, check this before you pay as many rebuilds are bad from the start because of this wear. This would be where the rod that the butterflys attach to, where this rod comes out of the carb body and you hook up your linkage to it to open the throttle on one end and the chock connects to the other end. Grab ahold of the throttle linkage and try to move the rod up and down, excessive play means its worn out.
1 - 2 of 2 Posts
