In the middle of redoing entire front suspension on 66 289 manual steering. Two questions concerning Idler Arm:
1) Attached new Idler Arm to frame bracket at correct torque and moved it around before attaching anything else. It turns on bracket, but a lot of resistance. Is this correct, or does any lube go between Idler Arm and bracket?
2) There is a foam washer in teh Idler Arm kit. Where does that go?
Many thanks.
Many thanks.
