Hi all - I think I have an issue with the idle mechanism in my 1964.5. Engine is 260, 2-barrel carb. Car takes about a minute to turnover on ignition. Once started up, I need to slightly depress the accelerator for about 30 seconds or so to give it enough gas to keep running. Sometimes, this is enough to get the car ready to run. Other times (more often than not these days), when I take my foot off the accelerator, the car stalls. This has happened to me at stop lights before as well, which can be an embarrassing event... Anyway, the other day I couldn’t get the car to keep running long enough to reverse out of a parking spot. I called a friend who told me it may have something to do with the idle mechanism. He walked me through adjusting the screw on the dechoke linkage assembly to “open up” the fast idle a bit so it didn’t close when I took my foot off the accelerator. I noticed there is a piston attached to the dashpot that slides in and out. I’ve been playing with this a bit trying to find the right solution, but I’ve yet to fully resolve the issue. I have also noticed that most dashpot assemblies online have a spring, but mine appears missing (if was ever there at all to begin with). I wonder if I need to replace this dashpot or the dechoke linkage assembly, or both. Even better would be if there is a quick fix with what I currently have in place.
Photos attached.
Thanks all
Photos attached.
Thanks all
