I am changing my ignition lock along with my door locks which are already finished. I got the old lock out, but when I put the new one in, it won't go back to the lock position, it only goes between start and run positions. Is there a trick to fixing it, or do I just need to try and "mess" with it. The car is a 70 mach 1. Please help, Daniel.
Discussion Starter · #2 ·
Use the paper clip on the new lock insert and rotate the front face relative to the rest of the insert. Play with the alignment of the parts until it fits in the hole.
Is the column lock arm connected to the trans wit a rod or not. I had the same problem and that was the reason. Also like the other response, you might ave to play with it a little and make sure the tumbler pin lines up.
