·Guest
Every since I replaced the non mustang switch with the correct one, I have had problems with the ignition. It will just die and then will not start. The problem is definately with the coil lead off the switch. I have rewired it and still the same problem. It is either my connections, a finicky resistor wire, or a bad ignition switch right out of the box. Is it posible to be the new ignition switch shorting out?.
